ForumindexMaskinforumThe Hymac ClubHymac History
Hymac?
40 inlägg • Sida 2 av 3
Discuss Hymac history here.
Diskutera Hymac-historik här. Obs! Forumet är på engelska!
Antevante
#16 » 18:39:11, 08-12-2015
Edner skrev:10 tusen 580 B. Eller 10 tusen 580?
Räknade i boken och 10 000 st 580 av olika modell stämmer ganska bra.
Jag har köpt grejer från, Hymac Parts http://www.hymac-parts.co.uk
Det fungerade bra.
Antevante
Maskin: Volvo L90H (Anställd)
Hymac 580BT
Hymac 580DS
MB Trac 800
Jeremy Rowland
#17 » 23:09:41, 16-12-2015
Hi there you are incorrect on the identity of that machine it is a Hymac 580 not the later 580B; if you let me have the serial number I may be able to tell you more about it.
Jeremy
Jeremy Rowland
International
Antevante
#18 » 00:09:16, 17-12-2015
Hi Jeremy! Nice with some input from you!
I assumed it was a B model because of the rectangulare cover over the brake drum. I guess my way to sort the A and B model was wrong...
Can you tell us more about the diffrences between the 580 and 580B?
/Ante
Antevante
Hymac 580BT
Hymac 580DS
MB Trac 800
Jeremy Rowland
#19 » 00:17:52, 17-12-2015
Antevante skrev:Hi Jeremy! Nice with some input from you!
/Ante
Hi there Ante :wave: yes I used to get mixed up myself until Tony Flint put me right on this; there are two main visible differences between the 580 and the 580B, if you look at the part of the undercarriage where the drive sprocket is, on the 580B it is a recessed plate whereas it is flush on the 580. The other difference is the end of the boom fork where the dipper arm fits; on the 580B this is strengthened with a welded plate, it is harder to spot this difference.
The early 580 machines did indeed have the round brake drum on the undercarriage but later ones had the rectangular cover; the machine in the YouTube clip is a later 580. :thumme:
Jeremy
Jeremy Rowland
International
Edner (trådstartaren)
#20 » 00:59:26, 20-12-2015
I will lock for a serial number.
How old is this machine?
Late sixties?
Edner
Ort: Grönlanda västra götaland dalsland färgelanda kommun
Maskin: Ursus 385 Delux
Kockum KS 836 -70
Hymac 580
Jeremy Rowland
#21 » 02:16:08, 20-12-2015
Edner skrev:I will lock for a serial number.
Late sixties?
Yes a rough guess would be between 1966 and 1968.
Jeremy
Jeremy Rowland
International
janebrink
#22 » 10:28:19, 03-03-2016
Great thread! I could also need some assistance identify my new purchase. Bought it last Sunday.
Seller claimed that it is a 1969 year model, but I don't know if it's a 580 or a 580b.
Also, where can I find the serial number for closer identification of year model?
//Anders.
janebrink
Maskin: Hymac 580b
Dynapac CG11
Belos redskapsbärare (gammal som s*t*n)
janebrink
#23 » 10:44:51, 03-03-2016
haha found my machine on this forum! In this thread:
janebrink @ Hymac 580 b in Sweden
So I assume that answers my question of the model. 580b
janebrink
Maskin: Hymac 580b
Dynapac CG11
Jeremy Rowland
#24 » 22:18:57, 03-03-2016
This machine is a later 580 not the 580B model a clear view of the drive sprocket gives it away as a 580 and not the 580B which has a recessed drive sprocket. The serial number plate is normally in the cab it could well have been removed or dropped off during the machines life.
Jeremy
Jeremy Rowland
International
janebrink
#25 » 23:10:44, 03-03-2016
Ok thanks for the input! :)
So the plate that covers the shaft to the drive sprocket is flush on a 580, but recessed on a 580b?
This bearing holder/cover plate is sticking out about 1cm. AND is recessed into the undercarriage about 4mm.
But I assume that the difference is becoming very clear when looking at the two models side by side? :D
janebrink
Maskin: Hymac 580b
Dynapac CG11
janebrink
#26 » 23:55:02, 03-03-2016
Just opened my parts manual for the 580b, and now I understand completely what you mean by recessed.
This is without a doubt a 580 without the "B".
Do you know if the parts around the drive sprocket fits both the 580 and the 580B?
My plan is to go 220km one way this weekend to buy used parts of a 580B. I need the shaft, the inner rear bearing retainer, and probably everything in between. But will it fit? Bild
Originalets URL: http://uploads.tapatalk-cdn.com/20160303/7f0131eddcace69d4977e2c594ebbcf4.jpg
I also went outside to look for my serial number. :)
Originalets URL: http://uploads.tapatalk-cdn.com/20160303/07b776e351f5baab1cb5db471dda09f6.jpg
janebrink
Maskin: Hymac 580b
Dynapac CG11
Jeremy Rowland
#27 » 22:40:19, 04-03-2016
Hi there; without talking to Tony Flint I could not tell you the difference between the two drives, all I know is that they were different but whether the sprocket tumbler is different or the shafts I don't know? If you let me know which parts you are after I can ask Tony as I know that he had a tumbler sprocket in his collection of spare parts.
According to your machine serial number it was built between April and June 1966.
Jeremy
Jeremy Rowland
International
janebrink
#28 » 00:38:54, 07-03-2016
Thank you for letting me know when it's manufactured. :)
As far as I've seen today, the only difference is that the front end of the "fork" is boxed in, making the bearing retainer recessed.
Tumbler sprocket, is that the big one that pulls the track?
janebrink
Maskin: Hymac 580b
Dynapac CG11
Jeremy Rowland
#29 » 22:15:30, 07-03-2016
janebrink skrev:Thank you for letting me know when it's manufactured. :)
Yes the tumbler sprocket is the drive sprocket for the machine; I have a 580B parts book here and it shows two types of undercarriage, the one of which looks very much like the one fitted to your machine, according to the pictures in the book there is a visible difference between the two drive sprockets with the later type being recessed to have a seal fitted into each side of the drive sprocket.
Unfortunately what the book cannot tell me is any size differences between the two sprockets and the drive shafts.
I am hoping to see Tony Flint very soon and will ask him to see what light he tell me about the two drives.
Jeremy
Jeremy Rowland
International
janebrink
#30 » 22:16:33, 07-03-2016
Sounds great! :) thank you.
janebrink
Maskin: Hymac 580b
Dynapac CG11
Återgå till Hymac History
cron
