Volvo BM 616B TD60
27 inlägg • Sida 1 av 2
Gibrill (trådstartaren)
#1 » 18:29:03, 11-02-2024
Hello everybody ! I currently have a Volvo BM 616B D42 engine HS crankshaft, piston cylinder, HS starter crown.... I have 2800€ costs for the repair.
I wanted to change engines but I can't find any D42 D45 TD...
I got it into my head to want to put a TD60 in my BM 616 HT65 automatic gearbox, I'm afraid the gearbox will be difficult to hold? Do you have any advice? maybe a TD50 would be more suitable? change the gearbox and the engine?
I know that the 6 cylinders are longer and that it is necessary to adapt a little if some have already done so I am looking for advice
If anyone has an engine for sale I would be interested too!
Thanks so much for reading!
Gibrill
International
Maskin: i have bm 616
Bygert
#2 » 20:13:42, 11-02-2024
On 6300 who has a corresponding engine it is rather common to swap for a Cummins 6cyl
Bygert
Maskintyp: Grävlastare
Maskin: Huddig 1160
#3 » 20:21:31, 11-02-2024
okey superb! Do we also have an HT65 box?
Gibrill
International
#4 » 20:46:36, 11-02-2024
No the 6300 has HT90
A D42 engine might be found on swedish scrapyards but they are popular.
Why is not your engine working after repair?
PeterR
#5 » 20:51:17, 11-02-2024
Send an email to TKs (scrapping old machines)
They might have an original motor.
https://tktraktordelar.se/en/produkt-ka ... vo-gm-616b
PeterR
#6 » 20:53:56, 11-02-2024
magloman skrev:No the 6300 has HT90
it was tight it ran without oil I bought it like that
but I prefer to upgrade to a more popular engine like the td60 than to spend 2800€ in a D42... In France we don't find any of the D42 engines I couldn't find anything on the internet.
even finding a td60 is a bit complicated but it will be super nice to have an engine that is so nice to listen to and drive.
The LM 846 were equipped with D60a 125 horsepower with the HT65 I believe...
Envoyé de mon Pixel 7a en utilisant Tapatalk
Gibrill
International
PeterR
#7 » 20:57:40, 11-02-2024
PeterR
#8 » 21:07:17, 11-02-2024
I contacted almost all the ads from memory it is around €3000...
Thanks you
Gibrill
International
#9 » 21:22:09, 11-02-2024
The d42 is a volvo made engine, in small numbers.
I would recomend to install a more common engine if you gonna swap it out.
Maybe perkins, ford, iveco, fiat or maybe some french commonly available.
#10 » 21:24:42, 11-02-2024
yes that's what I would like to do having very little information on the possible assembly in Perkins I looked at the famous td60 which would pass on the gearbox without problem I have the d42 bell which adapts
(I'm passionate about Volvo ) I would have liked to keep a Volvo engine
Gibrill
International
#11 » 21:39:15, 11-02-2024
Least amount of work with good success rate is to rebuild the engine you have. After that you never again have to do anything to it.
Crankshaft usually is repairable. They grind it.
You could send entire engine to a rebuild company and ask for a quote. Maybe shipping to sweden is worth it if no one closer wanna repair it.
PeterR
#12 » 22:40:36, 11-02-2024
The one in this ad is a replacement: you return your old motor and get a refurbished “as new”. I guess €3000 is a fair price. Note that you get paid for the old one when it’s returned.
Compare that with the cost to a swop to TD60
Gibrill skrev:
PeterR skrev:Another example in southern Sweden:
https://www.mascus.se/entreprenadmaskin ... gw9sj.html
Thanks you
PeterR
#13 » 22:42:39, 11-02-2024
magloman skrev:Least amount of work with good success rate is to rebuild the engine you have. After that you never again have to do anything to it.
You could send entire engine to a rebuild company and ask for a quote. Maybe shipling to sweden is worth it if no one closer wanna repair it.
I made this quote unfortunately the crankshaft is approved (it is bent) it is not repairable and the total price of the repairs exceeds my budget...
Around 3000€
Wouldn't switching to td60 be a good idea for you?
Gibrill
International
#14 » 22:56:35, 11-02-2024
PeterR skrev:The one in this ad is a replacement: you return your old motor and get a refurbished “as new”. I guess €3000 is a fair price. Note that you get paid for the old one when it’s returned.
Thanks you
yes it's for sure... a td60 I can find one for around €1500 delivered
my fears are more about the assembly and the gearbox if it can hold the power
Gibrill
International
fretchi
#15 » 01:11:27, 12-02-2024
I wouldn't worry too much about the transmission. The HT65 is sturdy, and was - as you previously said - mated with both D50 and D60 in wheel loaders 840, 841, 845 and 846
But don't expect a TD60 swap to be cheaper. Even though you can buy the motor for half the price, there are likely a lot of auxiliary components that needs replacing and/or modification.
fretchi
Användare som besöker denna kategori: osla och 4 gäster
