Rekreationsverkstaden
108 inlägg • Sida 6 av 8
tronde
#76 » 19:34:40, 01-10-2023
Litt bildesøk på google gir noe.
På russisk ser det ut til å være Микроскоп компаратор ИЗА-2.
På engelsk Microscope Comparator IZA-2.
Bruk google translate på disse.
https://www.chipmaker.ru/topic/133074/
https://oboruduy.com/moskva/raznoje/mik ... 93586.html
https://mash-xxl.info/info/646547/
Oversatt med yandex:
komparators
103
divisible radnuses of curvature 10-1000 mm . For ease of operation, the optical axis of the microscope is tilted at an angle of 45" using half a pentaprism and a rectangular prism.
Horizontal Crosscomparator-2
This device is designed for accurate measurements of lengths. It is built on the principle of a longitudinal comparator, in which the measured segment and the scale are arranged sequentially and rigidly
Fig. 69. The horizontal dashed comparator ISA-2
are interconnected. Due to its high design and operational qualities, the device finds a very wide application.
The measurement limits of the comparator ISA-2 0 200 mm, the division price of the main scale is 1 mm, the division price of the spiral ocular micrometer is 0.001 mm. A visual reading of 0.0001 mm is possible. L
The measurement error of the device is 0.9 300 - 4h) microns, where L is the measured length in mm; h is the height of the plane of the measured object above the plane of the comparator scale in mm.
Movable slides 11, sighting 8 and reference 6 microscopes are mounted on a massive base 1 (Fig. 69). On a sled
Oversatt med google:
Comparators
103
divisible radii of curvature 10-1000 mm. For ease of operation, the optical axis of the microscope is tilted at an angle of 45" using half a pentaprism and a rectangular prism.
Horizontal bar comparatorIZA-2
This device is designed for precise length measurements. It is built on the principle of a longitudinal comparator, in which the measured segment and scale are arranged sequentially and rigidly
Rice. 69. Horizontal line comparator IZA-2
connected to each other. Due to its high design and operational qualities, the device is widely used.
The measurement limits of the comparator IZA-2 are 0 200 mm, the division value of the main scale is 1 mm, the division value of the spiral ocular micrometer is 0.001 mm. A visual reading of 0.0001 mm is possible. L
The measurement error of the device is 0.9 300 - 4h) µm, where L is the measured length in mm; h is the height of the plane of the measured object above the plane of the comparator scale in mm.
On a massive base 1 (Fig. 69) a movable slide 11, a sighting 8 and a reading 6 microscopes are mounted. On a sled
tronde
Norge
BengtP (trådstartaren)
#77 » 19:45:15, 01-10-2023
Det var ett riktigt snabbt svar. Rätt bra precision verkar det ha varit på den, synd att det verkar fattas en hel del prylar bara.
Får försöka få bort det andra mikroskopet också, dock verkar det som överdelen är borta på det.
Jag lär ju inte kunna reparera den men jag får nog i alla fall ut ett bra mikroskop ur den.
Sen får väl resten hamna i materialhögen om jag inte kan komma på något roligt att bygga av den.
BengtP
Maskin: Myford S7 Svarv
Mattson&Zetterlund VF600 Fräs
Varator borrmaskin
Jungner US305 Verktygs slip
Deckel SO Stickelslip
Harrison M250
Meteor ME14 Borrslip
tronde
#78 » 19:59:08, 01-10-2023
Hva mener du mangler, bortsett fra okularet på det ene mikroskopet? Det kan være standard mål på det, og det er mange kinesere som selger helt OK kvalitet for lav pris.
Litt mer
https://studfile-net.translate.goog/pre ... r_pto=wapp
Ikke ødelegg noe før du er sikker på at det er vrak.
tronde
Norge
#79 » 20:08:19, 01-10-2023
Nej jag har inte sönder den innan jag har gått igenom den.
Vore ju rätt kul att ha det fungerande, man vet ju aldrig när man behöver mäta med den noggrannheten.
Hittade denna bild med hjälp av det du fick fram.
Det som saknas är överdelen på det västra mikroskopet och frågan är vad det innehåller.
Borde finnas några mätskalor i det.
BengtP
Varator borrmaskin
Harrison M250
#80 » 20:14:03, 01-10-2023
Kul. Sista länken du hittad är ju en användarinstruktion.
Intressant att speglarna ska vara matta på ena sidan, jag trodde att dom var felaktiga.
Tyvärr bekräftar texten att det är mätmikroskopet som saknar sin överdel.
BengtP
Varator borrmaskin
Harrison M250
tronde
#81 » 20:21:50, 01-10-2023
I den første russiske linken er det noen bilder. Hvor mye av det mikroskopet er intakt hos deg?
Hva er diameter i det hullet hvor okularet skal stå?
tronde
Norge
#82 » 20:29:02, 01-10-2023
Jag får kolla det nästa gång jag gör ett försök att få bort det. Vi får återkomma till denna.
Men när jag kollar närmare på en av mina bilder så kanske det inte är så mycket som saknas.
BengtP
Varator borrmaskin
Harrison M250
tronde
#83 » 15:26:12, 03-10-2023
Jeg fant et par russiske bøker som inneholder noe info.
Det som ser ut til å være relevant ligger i denne pdf hvor jeg har satt inn oversatt tekst til engelsk.
HorizontalComparator_IZA-2.pdf
Bøkene finnes her:
http://oldpc.su/lib/catalogs/mechITR.pdf
For denne er det linken til Cloudfare som ser ut til å virke nå. Denne filen er djvu-format.
http://library.lol/main/14801304a2395f4 ... d47e6c7426
Jeg tror det kan være smart å lage en egen tråd om denne komparatoren, for det kan være noen her på forumet som vet mer, men som ikke leser den generelle verkstedtråden din.
Google oversetter typenummeret til IZA-2, mens Yandex som er russiske, skriver det som ISA-2.
tronde
Norge
#84 » 17:14:26, 03-10-2023
Översättning från kyrilliska till latinska bokstäver blir ju olika beroende på vilket språk man översätter till.
ИЗА-2 blir mycket riktigt IZA-2 om man transkriberar till t ex svenska eller engelska, men det finns säkert andra språk där ISA-2 är mer korrekt.
#85 » 07:13:29, 04-10-2023
Tack för dokumentet, det var riktigt intressant.
Tyvärr bekräftar det att jag saknar en viktig del av mätmikroskopet. Överdelen som inte finns verkar innehålla bland annat linsen med mätskalan.
Frågan är om det ens går att få tag på dessa delar och om det är värt det på då tex axlarna är rätt rostiga.
Sen måste ju jag fundera på vad jag har för nytta av det om jag skulle få tag i dom saknade delarna.
Får se om jag får isär det lite mer i helgen så jag bedöma skicket i övrigt.
BengtP
Varator borrmaskin
Harrison M250
tronde
#86 » 18:08:42, 04-10-2023
Hvis du mangler alt som er markert med rødt, er det nok ikke lønnsomt. Men du har jo ett fungerende mikroskop som du kan lage stativ til, og det som mangler toppen kan trolig brukes sammen med et kamera som ikke har egen optikk (mikroskop-kameraer bruker normalt kun mikroskopets objektiv). Du har nok verktøy til å lage overgang som passer.
tronde
Norge
#87 » 13:25:26, 05-10-2023
Det är ungefär det jag också kom fram till, synd bara att det inte var mätmikroskopet som var helt.
Ska försöka kolla igenom det i helgen men risken är stor att det hamnar i materialhögen.
Men som sagt jag får ju ut ett hyfsat mikroskop ur det.
Du ska ha stort tack för ditt detektivarbete, mycket intressant som kom fram och jag blev rätt sugen på att rusta upp det.
BengtP
Varator borrmaskin
Harrison M250
#88 » 18:51:58, 07-10-2023
Har rivit isär den idag. Alla viktiga delar saknades på mätmikroskopet och den stora slipade axeln var rätt rostig. Det mesta hamnade i material/bra ha högen.
Mikroskopet som vad jag förstår användes till att positionera mätobjektet var i alla fall helt.
Gjorde ett provisoriskt fäste till ett magnetstativ och testade det i svarven.
Lyckades ta några bilder på skäret.
Svårt att ta bilder med en telefon med tre linser, slutade med att jag tejpade över två av dom.
Får nog vända på skäret, det ser rätt misshandlat ut.
BengtP
Varator borrmaskin
Harrison M250
tronde
#89 » 19:00:34, 07-10-2023
Et fungerende mikroskop for null kroner er heller ikke helt feil :thumme:
tronde
Norge
#90 » 19:04:22, 07-10-2023
Jo, jag får nog säga att jag är väldigt nöjd med det priset.
BengtP
Varator borrmaskin
Harrison M250
