Jag vill se bulthålstabellen, vilket har fungerat men verkar nu vara en bruten länk?
Jag har nu testat med 2 olika webläsare och det funkar fortfarande inte, nån som har nån aning om varför?
/Anders
såhär står det....
Warning: mysqli::mysqli(): (HY000/2002): Connection refused in /var/www/maskinisten.net/bultcirklar/index.php on line 193
Failed to connect to MySQL: (2002) Connection refused
Warning: mysql_connect(): Connection refused in /var/www/maskinisten.net/bultcirklar/index.php on line 198
Warning: mysql_select_db(): Access denied for user ''@'localhost' (using password: NO) in /var/www/maskinisten.net/bultcirklar/index.php on line 200
Warning: mysql_select_db(): A link to the server could not be established in /var/www/maskinisten.net/bultcirklar/index.php on line 200
Warning: mysql_query(): Access denied for user ''@'localhost' (using password: NO) in /var/www/maskinisten.net/bultcirklar/index.php on line 202
Warning: mysql_query(): A link to the server could not be established in /var/www/maskinisten.net/bultcirklar/index.php on line 202
Warning: mysql_num_rows() expects parameter 1 to be resource, boolean given in /var/www/maskinisten.net/bultcirklar/index.php on line 204
Warning: mysql_query(): Access denied for user ''@'localhost' (using password: NO) in /var/www/maskinisten.net/bultcirklar/index.php on line 252
Warning: mysql_query(): A link to the server could not be established in /var/www/maskinisten.net/bultcirklar/index.php on line 252
Warning: mysql_fetch_array() expects parameter 1 to be resource, boolean given in /var/www/maskinisten.net/bultcirklar/index.php on line 254
