ForumindexÅkermans[Åkerman] Historik
Åkerman EC620
42 inlägg • Sida 3 av 3
Åkermans historia är rik på skaparanda och innovationer
vildmarken
#31 » 22:12:23, 27-03-2012
The demolition machine is back from a job site.
Now it's time for some engine repair, and replacing the old cab by a new one.
vildmarken
Maskin: Volvo EW140C
Robban_C
#32 » 22:36:15, 27-03-2012
Is it a brand new cabin or is it a used one that has been repainted?
Quite a lot of money spent in that machine! :thumme:
Robban_C
Maskin: Volvo EC45 -06
Volvo ECR25D -17
MB-Trac 800 -86
Valtra N174D -17
ew160-raderat
#33 » 22:44:02, 27-03-2012
Is the new cab bigger, or does it just look like that?
well done :thumme:
ew160-raderat
Brynjar
#34 » 23:10:44, 27-03-2012
Is it because of safety you guys mount a new cab?? :smile:
Ingenting er umulig,det tar bare litt lengre tid....
Brynjar
Maskin: På jobb: Volvo 140blc 2006 mod.
Privat eie: Åkerman H7c 86 mod.
MF 35 Halvbander
vildmarken
#35 » 23:31:19, 27-03-2012
It's a 'new' unused original Åkerman NewComfort cab.
One of reasons they mount a new one, is that the old one could not reach the value' s for overpressure, to much leakage. In the Neherlands we need a pressurized cab with extra filters if (for instance) the excavator is working in area's with asbestos or polluted area's (sanitation).
vildmarken
Jevlar
#36 » 09:45:25, 28-03-2012
Aren't the biggest airleaks in the floor area where hoses and wiring pass through and around the pedals?
Jevlar
vildmarken
#37 » 20:30:59, 28-03-2012
That' s true and we will 'seal' this, but some parts of the cab were a bit damaged. The door is slightly bended, so we found a almost new cab at Volvo and offered this to the customer.
vildmarken
vildmarken
#38 » 22:07:17, 06-04-2012
So, the cab is almost finished.
But were is the valve bank?
The mechanics toke it to the workshop to put new O-rings in it.
vildmarken
vildmarken
#39 » 22:08:53, 06-04-2012
Here we are dismantling the cylinder, also to put new seals in it.
vildmarken
Nicklas86
#40 » 22:42:44, 20-12-2012
Tummen upp för firma namnet på tröjjan :thumme: :mrgreen:
Nicklas86
Maskin: Tw110
Brynjar
#41 » 18:20:10, 21-12-2012
Ja tar man bort en bokstav så....... :mrgreen:
Brynjar
MF 35 Halvbander
Anton
#42 » 18:52:36, 21-12-2012
Den gode gamle Åkermancylinderbänken.
/Anton!!
Anton
Grundare
Grundare
Återgå till [Åkerman] Historik
cron
